Gawd I'm getting toooo used to removing corolla engines.
extracted the tooth on the 20 yesterday and it took me all of 1 hour.( now what am I going to do for the rest of the day)
Ahh, you think I had outside assistance from no. 1 son, no. 1 who?
Whats your best time?
Hot 186 from a HK in 20 minutes, and I mean Hot !!!
Coppers chasing us through Carina, pulled into home and four of us got stuck into it and just finished as the coppers pulled into the yard (yeah they knew us).
"Nah mate, couldn't have been me, the motor's not even in the car." I said, while suffering 3rd degree burns to the hands.
ok...
engine and box out of rt118 corona : 16mins
engine and box out of ke55 corolla : 12mins
no assistance from rattleguns etc........just me and my mate jake
Shit, thats pretty good Andrew I'll remember you when I have to do it again.
I ( or should I say my back) remember doing it that way Nick (350 chevs) and then I got an engine lifter.
have pulled a motor and box out separately from a ke20 in under 10 mins.
was 4 of us, we rolled it on it's side, dropped tailshaft undid gbox bolts. the box was stubborn to separate, so i shook the shit out of it and it came away in my hands, and at the same time the engine mounts broke and the engine fell out onto the ground. was so funny, hahaha.
Good one Doug,
How about the more conventional method?
Shit, Ryan and I dropped one out under and then lifted the front of the 10 up and walked it back off the engine/box.
I must just suck - my best effort is 2 hours to remove the gearbox alone. Worst effort about 3.5 hours to remove the same gearbox. Haven't pulled an engine out yet, but it took me quite awhile to get the 4AGE into the KE35...
Edited by demuire
But from what I understand yours is not a standard ( easy ) job.
Repetition kicks in for me.
Jack the back of the car up really high, to get at rear uni and gearbox all in one hit, and mainly cause I can't get a jack under the front.
Underneaths all done, pop out gear lever and start under bonnet.
biggest pain is removing SU's to get to heat shield to get to manifolds.
Oh, I didn't mention the time spent jawing and the lubrication.(deduct from 1 hour)
Tony Scott and co changed a clutch on his KE70 Rally car in 19 minutes from the moment the car stopped to the moment it left, in a paddock, to a hot car straight out of the stage. Dave Gaines did a diff by himself on the Fat Lady 240K in 21 minutes in the same conditions.
I usually do a motor in an hour or so. No need to hurry these things. :D
Should we perhaps clarify it to, how long does it take to remove an engine from a car that you want to put an engine back into? If not, side cutters rock when it comes to disconnecting wiring, fuel lines, radiator hoses, clutch cables.......
Edited by Redwarf
really what is the point of rushing these things when you miss things and have to do it all over again? not so bad if you are just pulling an engine from a wreck. or maybe if you have to in a rally situation with time limits.
i've rushed a clutch change in the past and found weird noises when i went to operate the car. turned out i put the clutch plate in back to front and it was rubbing on the flywheel bolts. wasn't to happy with myself having to do it again. learnt a valuable lesson.
these days, i'd rather take my time doing an engine change. at least i know then the car will start first go, because i haven't missed something stupid. a ke1x with extractors slows things down, due to space constraints, compared to later cars. you don't pull the motor and box separately, takes waaaayyyy longer.
It may take a little longer to remove but i would rather line up the spigot on the deck than crawling around under a car ( Either cold concrete or the attack of the killer bullants, aaarrrgghh)
