**chumps** Posted May 15, 2007 Report Posted May 15, 2007 Hey guys and girls just wanted to know what would be cheaper to do to my 5k. Turbo or supercharge? cheers Ben :cool: Quote
flat out Posted May 15, 2007 Report Posted May 15, 2007 depends on if you want carb or efi, draw thru car setup with a supercharger is most likely your best bet, from there mabey blow thru turbo, your choises realy are s/c draw thru s/c blow thru s/c efi turbo blow thru turbo draw thru turbo efi note you will need a large su carb for draw thru and if its turbo you want it needs to be carbon seal also you can't run a bov or intercooler with draw thru Quote
MRMOPARMAN Posted May 15, 2007 Report Posted May 15, 2007 it really depends on what sorta deals you can get on various things, whether going going new or 2nd hand stuff, whether you can fab or not etc etc etc i havent had the chance to do either as yet, but i think for ease and cost a J pipe turbo using an EA CFI throttlebody and 2nd hand ECU would be hard to beat Quote
**chumps** Posted May 16, 2007 Author Report Posted May 16, 2007 (edited) well i was thinking of doing turbo blow thru coz i can get a rebiult t04 for $200. Ive got a 32/36 carb laying round and a compleat 4k. But how much could i pick up supercharger for. cheers Ben Edited May 16, 2007 by **chumps** Quote
MRMOPARMAN Posted May 16, 2007 Report Posted May 16, 2007 mate, i think you'll find the TO4 a bit big, and the carb a little small for the task. basic toyota superchargers usually sell in the region or $2-300 Quote
**chumps** Posted May 16, 2007 Author Report Posted May 16, 2007 (edited) hmmmm i think ill go for a blow thru turbo set up.The 5k has been board out 40thou and has extra dished pistions with a shaved and ported head. I shouldnt have any problems with it holding boost should i cheers Ben Edited May 16, 2007 by **chumps** Quote
flat out Posted May 16, 2007 Report Posted May 16, 2007 depends what head and how much it has been shaved, close to stock compresion should make it fun to drive off boost. porting is good to Quote
aidaniel[RL] Posted May 17, 2007 Report Posted May 17, 2007 less compression is your friend when i comes to boosting a motor, run close to stock commpression and you should be fine Quote
