July 12, 200719 yr comment_186622 Hello everyone. Its starting to really annoy me driving the car without the services of a tachometer. I would hook it up in a snap if only it wasn't Coil Over Plug. Just wondering if anyone has devised a method of modifying the standard tacho circuitry to use a signal from the coil over plug Ignition. Ive heard its possible, but no-one has been able to give me any specifics. Thanks for your help. Report
July 12, 200719 yr comment_186634 This link may be helpful http://www.rollamods.com/tech/ae86gzetacho.pdf Failing that I know where you can take it to get it sorted.. http://www.ottoinstruments.com.au/index.htm Not fully clued up on coil packs and stuff yet but if you run a wasted spark setup (multicoil) The following diagram may also help.. Justin........ Report
