August 1, 200719 yr comment_189712 need some push rods asap ! just got a cam in but the push rods are to long and the supplier has none in stock please reply with numbers and cost if possible cale12 Report
August 1, 200719 yr comment_189724 I would assume from your other post that this is for a 5k? :( Use some chevy solid lifters, and datsun A12 push rods to convert it to solid lifter. :D 5k's are hydraulic if you didn't know. :n: Report
August 1, 200719 yr comment_189737 If you are after 5k pushrods for hyrdaulic lifters then give Crow Cams a call in Victoria. They do custom chromoly pushrods for the speedway boys who use 5k engines. don't have the part number on me, but just give them a call and tell them what you are after. Be prepared though, because aren't exactly cheap. Good luck. Davros Report
August 2, 200719 yr comment_189858 push rod=loose :n: cam thats in the head OMG!! j/k, no reson that it can't be made to perform well, i know several push rod motors that will out rev dohc... Edited August 2, 200719 yr by tas_ae71 Report
