Ke55 Died
hey all. . the rolla wouldnt start 4 awhile so i took stater motor out and rewired it all back up, new plugs , new leads and new engine fuse.
It still wouldnt work so we push started it and it worked fine. Turned it off and it started up straight away, so i took it 4 a spin around and it died it the middle of the road and now i have nothing no power anywhere not even my alarm. . WHATS HAPPENING??
Any help Please. .
thanks Josh
For fear of stating the bleedingly obvious, I will anyway... Have you checked the battery and terminals? If batteries are left without charge for too long (like a week is long enough) sulphides build up and they don't hold charge for longer than a few minutes.
yeah ive even tryed a different battery still nothing. . il charge the 2nd one might off been flat or somerhing. . at least i hope so anyway.
gday mate have ya been welding on the car at all recently, coz the other day wen we did my ehaust it blew 2 fuses i think it was and it also didnt want to start!?
nah no welding. . was thinking off doing the diff :), il jst ger her fixed up and nice for now.
Have you looked at the alternator?
nah . . everyone said just to go with starter, all wires to alternator seem to be intack but nah havent taken it off and had a good hard look.
If you have acses to a multimeter check the battery voltage with the engine runing at the battery. it should be between 13.8 and 14.2 volts.
next check the voltage at the alternator output post {positive red} and the negative terminal on the back alternator housing {black} if the readings are Different You have bad connections somewhere. pm me for more help.
the Rolla is back now . . all good n fixed up now got my ps 2day aswell, just had it out in the wet :)
