wilson_610 Posted October 16, 2007 Report Posted October 16, 2007 (edited) as the hill climb gets closer its time to pull my finger out. BUT i have this diff i got with another car. but i have no idea what it is!!! its a jap style. (ie have to remove tail shaft to unbolt and remove centre). will i find an LSD for it cheaply??? or do i need to invest in axels and CIG the centre??? Edited October 17, 2007 by wilson_610 Quote
styler Posted October 16, 2007 Report Posted October 16, 2007 could be a jap spec t series seeing it is a banjo front loader, has discs and coil sprung with link setup. Quote
wilson_610 Posted October 17, 2007 Author Report Posted October 17, 2007 this is the best i can do... the camera in my phone is now f---ed but need to build new race car so it has to do till thats finished... Quote
Des Posted October 17, 2007 Report Posted October 17, 2007 Take the center out and count the teeth on the crown wheel and pinion and divide them together and you will get the ratio. Also look to see if its and LSD, Look for clutches as they seem to be popular. Quote
wilson_610 Posted October 19, 2007 Author Report Posted October 19, 2007 (edited) well i pulled the axels out tonight. they have 23 teeth on the spline. the axel bearings are about 2 inches long and the centre is open. the ring gear is roughly 4.11 well more than 4 turns but less than 4.5 but not too worried about that. just after what type of axles type i have so i can chase up an LSD center for it Willie Edited October 21, 2007 by wilson_610 Quote
irokin Posted October 20, 2007 Report Posted October 20, 2007 How many inches is the ring gear? Quote
wilson_610 Posted October 21, 2007 Author Report Posted October 21, 2007 (edited) the ring gear measures 6.5" after searching a international spoonta site i found a sit that broke down (with pictures) the ae86 disc rear end... i have found i have Zenki axels Edited October 21, 2007 by wilson_610 Quote
