Is there an auto tranny that will mate up to a RWD 4AGE?
It's for my daughter's KE55. All I can find is manual info for the engine swap.
Any others? I am also looking at a TA2 which has the auto box.
Is the pushrod TA2/TA12 ok?
You can use the AE71 A40 3 speed auto but you will need an 8 bolt flex plate from a late model 4age, I'm using a auto behind my 4agte but i can't remember what model my flex plate came from but here are the pics (POST 64):
http://www.rollaclub.com/board/index.php?s...2422&st=60#
EDIT: The reason i say late model 4age is that that is the generation that came with an auto.
Edited by Trev
There was a RWD 4 speed unit found behind some 4A engines but they were only available overseas.
Something that could work but haven't tested, is to use a 4speed A40D tranny from corona RT142 or celica RA60/65 combined with the bell housing off the A40 3speed unit.
slightly off topic here... with the t50, it has a hydraulic clutch, but can this be modified to just be cable clutch? cheers everyone
Just mod ur car to use a hydraulic one! :)
  • 3 months later...
I backup what Trev said, the one you want is off an ae71 auto, their easy to come by and probably worth penuts. From what I hear its actually a Trimatic with Toyotas own bellhousing.
  • 2 months later...
