Weber's Twin Cam Seca
Happy old fart day bro!!!!!
  • Replies 69
  • Views 57.6k
  • Maybe pinch Trav's, Jono.C? I'm banning myself from playing with this engine!! Before you know it she'll have 300fwkw and webers will have no money. :)
  • webers4x48
    webers4x48
    Sweet :) You're more than welcome. No tools needed though. I should have everything. I think I need a WTF sticker more :)   LB
  • We haven't seen webers around the forums for a while, but in answer to your question, the bumpstops will only need changing if they are flogged out. Which will happen with KS Super Lows as I found out
How's the new setup coming along?? Hahahaha!
Update tomorrow......
All I can say is its awesome!!!!!!
What update?? We just changed the gaskets on the 4AGE!! Haha
Edited by kickn5k
  • 1 year later...
Hey man, I don't particularly like necroing threads in forums, especially forums i'm new too, but, I have an ae82 liftback, and am considering getting King Springs Super lows (2" drop), the same that I believe you have, and I was just wondering..
Did you need to change your bumpstops at all????
PS. First post, woowoo!
PPS. I have actually been stalking these forums for ages. :P
We haven't seen webers around the forums for a while, but in answer to your question, the bumpstops will only need changing if they are flogged out. Which will happen with KS Super Lows as I found out the hard way, also bear in mind the springs will most likely not be captive.
Not be captive?
What do you mean by that?
And also, what bump stops did you use to replace them???
By not captive, it means that if you jack the car up & the shocks/springs are fully extended, the springs will not be held in place but will be loose & can potentially fall out of position. The same thing can happen going over bumps on the road.
I used standard replacement bumpstops, available as a kit with dust boots etc from most auto-parts stores.
