Converting Ae71 To Manual
I just did a search but came up with nothing, my question is in regards to the slave cylinder and pedal box set up. I'm gunna have to drill the holes for this thing aren't i? is it easy to do with the intake manifold still on?
I believe you mean master, not slave? On that asumption you will have to drill some holes in the right spots to fit the things yes. The manifold is up to you, its your car, do whatever has to be done.
Master cylinder, thats what i meant. It was obvious i have to drill holes, just wanted to make sure. Thanks.
