November 19, 200719 yr comment_210299 Hey all, new to the rollaclub. i had a n13 pulsar and was dissapointed with their overall bodyshape/engine and decided to move to a ae92 cs rolla. I'm wondering if anyone knows how easy it is to put either a 16v or 20v 4age into a 1991 CS corolla. what needs to be done in terms of customizing eg. engine mounts etc??? any help would be greatly appreciated and I'm only writing a new topic as ive tried to search but it comes up with nothing every time. cheers all and look forward to cruising with you guys when my project is finished!! Report
November 20, 200719 yr comment_210404 you should just by an ae92 sx. it will come with the good motor and all the nice bits from the factory. besides, they are so cheap as chips now (but not as cheap as the CS) it wouldn't be worth the time and $$ to convert a CS. Report
November 20, 200719 yr Author comment_210463 cheers, are the sx model a hatchback and if so do they have anywhere near as much power as a 4agze or 4age 20v blacktop? Report
November 20, 200719 yr comment_210517 the sx come in liftback (seca) and hatchback. they have 100kw at the motor compared to about 120kw (advertised, but usually less) than a GZE or 20V. Report
November 21, 200719 yr comment_210566 get the 20V silvertop or blacktop... the rolla shall fly! Report
November 22, 200719 yr Author comment_210899 does a 20v silvertop fit directly into the ae92??, eg no custom engine mounts etc? any more info would be great but youve been very helpful so far Report
November 26, 200718 yr comment_211353 the silvertop IMO is a complete waste of time. black top with a 6 speed, fair improvement, but their are a few mods that are required. power steering needs some mods from memory,possibly a new high pressure hose gearbox mounts and possibly custom linkages wiring for ecu etc. airbox mounting(it is not cool to have things floating wildy in your engine bay) There may be other things that are required, but its been a long time since I completed this conversion, and I just can't remember. Also don't expect to find a blacktop front cut for less than around $2500, plus all your mods and fittings etc, plus a new clutch, timing belt, pulleys, seals, and if you really want to be safe, water pump. You may as well do all this stuff while the motor is out, adding the peace of mind gained from knowing that all these parts are new, because even though most front cuts will say 100k on the odometer, its never true. Edited November 26, 200718 yr by Rollaboy2608 Report
December 20, 200718 yr comment_216107 While we are on the topic, would a 7AFE fit the 91 CS easy or would you need custom mounts n other mods? Report
December 21, 200718 yr comment_216154 If it will bolt into a 1987 twincam corolla (it does) it should bolt into a 91 CS, may have to swap some mounts around, but definitely no custom stuff. Report
December 31, 200718 yr comment_217416 If it will bolt into a 1987 twincam corolla (it does) it should bolt into a 91 CS, may have to swap some mounts around, but definitely no custom stuff. oh ok, Kool! but how much would a 7AFE go for these days? i got a quote from Ichiban for 4AGE Blacktop 20V + 5spd manual gearbox: $1300 Ichiban i don't think stocks the 7afe :dance: and how much would a 4AGE swap in an AE92 usually cost? like just the manual labour ascides engine price. what about the 7AFE? how much? i can barely find out advertised for sale Edited December 31, 200718 yr by Hans Report
