November 29, 200718 yr comment_211978 hello people i have a bit of a problem, i've got a ke20 that is nearly ready to go back on the road. the problem i have is that i got told to put on ke55 front struts as i had drums, now the top spring carrier is grabbing the strut tower. i have turfed the old struts and they are well and truely at sims by now, what other cars struts will bolt straight in with the spring being the same diameter as the original ke20 items? please help Report
November 29, 200718 yr comment_211983 well obviously go get another set of ke20 struts, other struts wont fit without modifying and even if they do you will have to take time and money to modify them and then they will affect the front end geometry too much if you don't know what you are doing. ke20 came with drums front and disk front. go find disk front struts and upgrade to the ke70 brakes another time. Edited November 29, 200718 yr by styler Report
November 29, 200718 yr comment_212184 Yeah agreed with styler , your cheapest easiest option is KE2# struts just a matter of finding some i suppose , there is R31 skyline which has the same steering arm bolt spacing but you'd need to change the the spring/spring seat Report
November 30, 200718 yr Author comment_212304 its all good i got some today and it was a major pain in the arse finding some, cheers gents Report
