Help: Ke20 Strut Problem
hi people i have an issue with my ke20 struts, firstly i have put ke55 brakes on to the ke20 struts. my problem is that when i reverse, the top of the wheel grabs the strut, so i thought no problem i'll put new wheel bearings on. this hasn't helped and its still doing it. now is their a different size ke20 stub axle or do i use ke20 wheel bearing? I'm stumped, please help
Bearings wont do a thing, Get a smaller profile tire ?
Pics will help us
Des :P
its grabbing below the spring carrier and only when i reverse the car, its giving me negative camber. when i drive forward it gives positive camber. i didnt have this problem when i had ke55 struts on but i had to change the struts as the spring carriers were to wide.
All discs are all interchangeable (the Corolla hubs are the same except for wheel stud pattern), or if you change hubs as well, KE1x and 2x have smaller inner wheel bearings than the later cars. If changing from smaller disc to larger disc, you will need caliper mounts from a KE30 or KE55, as KE70 caliper plates have a different stud pattern. On most KE1x/2x cars, you will have to drill a tap the caliper mounting plates to M10x1.25, as the later model plates use larger bolt holes to mount to the strut.
courtesy of superjamie, from the faq
