Te71 Diff, What Model Is It?
well, i pulled a diff out of a car for someone who wanted it gone assuming it was a standard ke70 diff.
but his car was in fact a 4 door te71 from south africa or somewhere, i get the diff home, and its not the same as a ke70 one.
i don't need it and curiosity is nagging at me wondering what it is.
has drum brakes of 230mm minimum, as opposed to the 202 on a ke70, has an 8 bolt backing plate, and the tag on it says.
9g-2950007
M68 ratio: 4.11
097
58724
cheers, andrew
banjo or salsburry? could be the same as ae86 (?) lsd if its banjo and being import, the one i have here hasnt the tags and is disc so can't realy give any info sorry
borg warner. not banjo
Do you know what the ring gear size is, I have a listing and for the TE7#'s listed it has T Banjo (including LSD) and 4 pinion S Banjo, If you can get that ring gear size i may be able to help out more without the ID tag code.
justin, i didnt think of it because i thought/had been told it was just a standard ke70 diff.
i don't know it, but i could
but its not a banjo type diff
