January 19, 200818 yr comment_221699 I have just bought an 86 corolla hatch. It has the grill with all the little squares. The car was in an accident befor i bought it and this grill is cracked wich is ok because I'm not realy a fan of the look. I was wondering if I would be able to replace it with the straight grill out of an 88 corolla??? any help would be great. Report
January 19, 200818 yr comment_221711 As far as I am aware as long as it is from another ae82 it should fit. They usually have one screw holding them in the middle and about 5 other plastic clips around the outside edges.. Report
January 20, 200818 yr Author comment_221794 ok thanks alot now the task of finding the grill begins ill just try the reckers :D Report
January 20, 200818 yr comment_221795 It will fit straight on as its a series 2 grille, Series 2 onto series 1 takes a little modification, I'm still trying to work out whats different as the head lights are all the same but i think they are positioned a little more to the outside. Edited January 20, 200818 yr by Trev Report
