January 30, 200818 yr comment_224151 Hey everyone put new lca in my sprinter and the alignment is off bad enough that i can't drive it,. just wanted to know what the procedure is to get the wheels straight enpugh to drive the car to a shop. Any help is apreciated, cheers Stefan. Report
January 30, 200818 yr comment_224168 tape messure, inside tyre to inside tyre across front end, front of hub, rear of hub, adjust till their about the same distance, go to tyre shop :hmm: Report
January 30, 200818 yr comment_224222 meaure the thread of each side ect like 1,2,3,4,5,6,7,8,9 then u hit the bolt make it that either side and check the angle of the rim be better if u had something to put under the wheels to make them slide on angles when u lossen or tighten or the bolts will be screwed in no time Report
January 30, 200818 yr comment_224253 How far is it to where you are getting the alignment done? Just eyeball it and drive it there if it is close.. Report
January 30, 200818 yr comment_224261 you can do a wheel alignment the old way with string, wood studs and some chalk i think. might have to look it up on google or something... Edited January 30, 200818 yr by styler Report
January 31, 200818 yr Author comment_224572 kewl cheers every one will do the tape measure way and check using the threads. Thanks heaps Report
February 1, 200818 yr comment_224780 http://www.honda-tech.com/zerothread?id=597192 http://honda-tech.com/zerothread?id=267237 Also google for "simple strings wheel alignment" Report
