Ke5x-70 Diff Into Te7x
does anyone know if the whole diff from an early corolla (ke55,ke70.etc) will bolt into a T-18?
A KE70 sedan diff will bolt in a TE72 (T-18), if you use the tailshaft also.
A KE55 diff uses leaf springs so will not bolt in unless yoou do alot of modification.
DO YOU KNOW IF THE AXLES ARE THE SAME OR IS A DIFFERENT DIFF WITH SIMILAR MONUTINGS, ALL THE T-18 DIFFS GO QUICK AT THE WRECKER DUE TO THE AE86 SPRINTER BOYS.
T series diffs are bigger than K series(ke70). People use T18 diffs as an upgrade for a ke70 as they're bigger, so it seems a little backwards to do what you're suggesting. :'(
Half the reason why they're used for AE86's is readily available LSD's. If you go for the ke70, there is no LSD available.
What exactly is wrong with your diff? just a rooted centre?
theres nothing wrong with the diff at the moment I'm just tring to find out for when i do break it, as it is enevitable
