Sand Blasting Calipers
HRV-00S
I have sandblasted heaps of calipers, no problems at all.
They should use sand which has been used a few times already so it is worn and less abrasive :D
These were done and painted up and are going on my car. I did them with the rubbers still on and put a M10x1 bolt in the bleed and inlet.
After blasting, I fully strip them, clean, paint and reassemble.
Edited by VHR32
I found out today that we run glass beads in our shot blaster at work, I used it to clean up the strut brace that I'm making at work/Tafe. It was a pretty grubby bit of alloy checker plate (no before shots) but the blaster made short work of it :abuse:
This is kind of a before and after,
Wire wheel on the left, blaster on the right.
and the rest,
I think I'll do what VRH32 has done, plug the holes and leave the old seals on. I noticed one has a little tear anyway maybe 3mm long so I'll glue that up and go for it, Then put a kit through them. I like the raw aluminium look to, might leave them at that :owned:
