Sand Blasting Calipers
I have sandblasted heaps of calipers, no problems at all.
They should use sand which has been used a few times already so it is worn and less abrasive :D
These were done and painted up and are going on my car. I did them with the rubbers still on and put a M10x1 bolt in the bleed and inlet.
After blasting, I fully strip them, clean, paint and reassemble.
Edited by VHR32
baking soda.
it explodes when it hits the surface and cannot be reused
but it also dilutes and washes away
you do not want to damaged where the seal is for the piston, under the rubber dust covers around the piston, it you do you may very well ruin the callipers, but if you do it as vhr32 has then you could probaly get away with it with..
what about soda blasting?? there's a place at lonsdale that do it, it's less abraisive than sand....
thats what i said soulsearcher :hmm:
I found out today that we run glass beads in our shot blaster at work, I used it to clean up the strut brace that I'm making at work/Tafe. It was a pretty grubby bit of alloy checker plate (no before shots) but the blaster made short work of it :abuse:
This is kind of a before and after,
Wire wheel on the left, blaster on the right.
and the rest,
I think I'll do what VRH32 has done, plug the holes and leave the old seals on. I noticed one has a little tear anyway maybe 3mm long so I'll glue that up and go for it, Then put a kit through them. I like the raw aluminium look to, might leave them at that :owned:
