April 7, 200818 yr comment_237830 If your keen have a lathe you can rip the internals out of a camira dizzy adn use them yes ona K motor :dance: Also use the ECU for the TBI version and the TBI setup. But better off getting 7K-e gear really. Cameron Report
April 7, 200818 yr comment_237883 Yep, like vacuum advance, but better. I've got no idea about the coil. Probably says somewhere in the Build manual for the prog ignition. Just had a look in the Bosch ignition catalog. Some sigmas DO share the same cap and button as the corolla bosch dizzys. The sigma ones don't have any listings on points, so I'd say they are electronic. Might be able to mix an match parts? Report
April 8, 200818 yr comment_237995 If your keen have a lathe you can rip the internals out of a camira dizzy adn use them yes ona K motor :dance: Also use the ECU for the TBI version and the TBI setup. But better off getting 7K-e gear really. Cameron The ECU's a Delco. Not to hard to make it programmable. Report
June 2, 200818 yr comment_250414 I've been digging and reading about this JAycar kit. Sounds like good fun. Anyway, I have a question: Could I use either the Prog. HEI unit or the Coil Driver to trigger an MSD 6AL? Thus, get the joys of ignition curve control coupled with the fat beefy multispark of the MSD? Report
