June 15, 200818 yr comment_253601 hello all, I've had the rolla for almost a week now and minor mods have begun. I've ordered the new "fully Hekitk" white faces for the dash and I want to replace the lights too since they aint the brightest. Can anyone shed some light on the situation? excuse the pun cheers guys Report
June 16, 200818 yr comment_253731 how ya going i thought that the dash lights were dim in my 85 seca, then i found the thing to turn the voltage up to them and they got brighter magically. have a look mine was under the steering wheel. cheers scott Report
June 16, 200818 yr comment_253801 check the reostat just below the steering column. or you can change the globes for L.E.D lights as i have done. Report
June 16, 200818 yr Author comment_253875 The dial was the first thing I checked when I got the car, she's cranked on full but still dim as. might drop down to repco and see if they have anything to offer. Report
June 17, 201214 yr comment_610362 Hi all, I spent a significant amount of time last weekend trying to replace some dash lights that have blown. I could not work out how to change them. So I am in need of assistance. I removed all parts of the dash surrounding the instrument cluster, so the screws holding it together and in place where exposed. I attempted to take the dash apart, first trying to remove the instrument cluster as a whole, but I could not unplug the cables attached to the rear, thus prevented me from removing the unit as a whole. Second, I tried to remove the clear face, followed by the black plastic moulding. This looked like it would be more successful. In fact, I think it it wasn't the SX cluster this would have worked. That is, after removing all screws, the clear cover & black plastic could be pulled out a little on the right hand side of the cluster. Yet the left hand side, where the clock, oil pressure and voltimeter are wasn't going anywhere. Can anyone provide any tips on how to remove the sx cluster? I have searched and have found nothing enlightening. Also, what globe will I require? And quanitity? The lights are out on the right hand side, i.e the temp gauge, and the tacho from about 4000rpm are not lit up. I guess one or two globes are blown? Thanks in advance for your help. Hopefully someone can save me. Justin. Report
July 1, 201214 yr comment_613185 Remove all the plastics surrounding it, top and bottom, then undo all the bolts and screws around the whole thing. Pull it out and all the wiring clips off. Report
July 1, 201214 yr comment_613195 Thanks Subaru_kid, there must be something I am missing, because I removed all visible screws. I removed the ones holding the clear plastic to the black plastic surround and the ones holding the black plastic surround to the white support/backing plastic. The right hand side of the dash (i.e. from the fuel gauge to the right) seemed like it would behave as you suggested. However, the left hand side (the area with the clock, voltimeter and oil pressure guage) was still held firmly together by something? At the base of the LHS there are 3 holes in the clear plastic and the black plastic surround has three nubbins that sit insite the holes. The ends of the black plastic where rounded, forming a sort of rivet like connection. I could try cutting/grinding away these rounded ends? But there also seemed to be something else holding it all in place? Hmm, I shoud have taken some photos when I had it all apart. I guess that it wiill be a job for my mechanic or an auto elec, for there where no more screws to remove and I don't want to break it. Thanks for your reply. any further insight regarding the SX dash cluster would be appreciated. Justin. Report
July 2, 201214 yr comment_613248 I think you are making a mistake by ripping section by section of the dash cluster apart. Take the whole thing out and you should be able to tackle the lighting from behind.. or atleast have more room to play with when it is out of the car. The cluster comes out as kne whole piece. From the clear plastic to the guage faces to the white backing... all in one go! Report
July 2, 201214 yr comment_613251 I tried all in one go first. And it was certainly loose, and would come 15 or 20mm forwards before stopping. It felt like and I assumed (perhaps wrongly) that this was the cables preventing me from pulling it any further. I had a ke10 and a ke55 before this car, and those clusters came out all in one go, so I assummed this would be the same. However, for some reason it does not want to slide out far enough for me to disconnect the cables. But if you are sure there is enough length in the cables to pull out the unit as a whole, I will have another crack. Thanks again. Report
