Engine Conversion
hey I'm new to this site an just brought a KE70 overrated condition done 140,000 its been lowered thats it
I'm wanted to put a bigger engine more realiable an more power into my little beast,
what is the easyest, conversion done so far, on whatever engine, i don't have a preference on engine so anything is ok,
looking to spend under 5grand to get this done, I'm a fabricator by trade so cut an making things fit shouldnt be a problem if this helps,
I'm only all the time so please help, will repay helps with big burnout on video :)
With $5k, I would personally go for a 4AGE conversion. Been done many times before and pretty much a straight forward conversion except for the hydraulic clutch installation (only need to rip out dash and drill a few holes, but pain the arse from what I've heard).
Many threads on what's needed to be done.
Congrats on finding a overrated ksev.
With $5 grand go with a 4age its a bolt fot bolt swap.
You need:
4age
T-50 box
4a series engine crossmember + engine mounts
Gearbox crossmember from an ae71
ae71 tailshaft
ae71 pedal box
Cluch master and slave cylender + lines.
There is plenty of info on this site on how to do this conversion. Open engine conversions, and find the step by step guide
read it carefully.
good luck with it hope this helps.
hey thanks heaps guys, i don't knwo much about toyota engines, so what some easy upgrades on these engine an what sort of power will i be looking at ?
its not that bad i did a pedal box swap and installed the master in about 2 and a half hours the other day.
anything but a ca18 will be fine haha
hey thanks for the suggestions, i reckon ill go with a 4age engine, whats it like to turbo one of these engine ? worth it ?
also the corolla i brought is a auto, but the guys said its got a manuel pedal box is this a help in any way ?
They are good to turbo. Very strong. Buy a 4agze if you wanna do that. Just remove the supercharger and turbo it as is.
