Hey guys i need to know what this part is called. My mate drove my KE70 into a gutter trying to drift it and he has bent it. The part that has the blue arrows pointing to it!
Edited by interlopr
cheers mate. is it also known as an LCA?
Yes it definately is your Lower Control Arm
and if it bent, chances are other shit has too.
my mate was drifting his car and undered into a gutter, we thought he bent the lca, can't remember if it actually ended up being bent or not but yeah, we replaced it.
it had moved the castor rod around a little so we also replaced that also and it was still pulling hard one way so we got a wheel alignment and was all good.
if it doesn't appear bent and is just pulling herd to one side, try getting a wheel aligner to check and adjust the castor. he will soon tell you if something is up or not.
