I have installed a new thermostat in 1993 Toyota Camry LE and there is very very minimal heat. I live in Canada Burrr. Please any suggestions as to what else could be causing this.
Edited by hendy
ugh...yes it is the correct spot to be posting... :D ? ?
when you say very minimal heat -> as in the car doesnt heat up to normal operating tempture?
You might not have selected the correct thermostat temperature range. It also doesnt help when your from Canada where 90% of the country is experiencing sub 0 temperatures. Increase your thermostat temperature and when summer comes your going to have to swap back to your current one I guess (don't not run a thermostat. The coolant needs resistance so that it can pickup the heat. Your temperature gauge might show a good temperature but there will be hot spots inside the engine where the coolant flows past too quick and can't pickup enough heat).
