June 25, 200818 yr comment_255832 hey guys I was looking into a set of Type-RS RX7 rotors and calipers if I can fit them onto my KE25 - if not I might go a brake upgrade kit which gives me practically the same size however in both situations i need a 1" bore master cylinder. I have a brand spanking new series6 rx7 brake cylinder which I don't need for my rx7. is it possible to fit this to my KE? Report
June 25, 200818 yr comment_255875 I think that Jono on here uses a series 6 RX-7 on his KE20 , wasn't a bolt on but it works now , pm him and ask him about it Report
June 25, 200818 yr comment_255888 i use a series 6 rx7 master cylinder in my ke20, but it uses remote reserviours from an integra. Report
June 25, 200818 yr Author comment_255940 cheers guys :( I don't really want to be buying yet another master cylinder lol, am already spending plenty of $$$$ on it. Thats good info though - Jono, is that from a DC2 model integra? possible to get a pic of the setup under ur hood? also what did you do with the rear brakes, still running drums on the rear or did you upgrade the rear to disc as well? my drums are absolutely scr**ed cause of the dumbass before me putting the shoes in them the wrong way and looks like 1. It's going to be hard to source some replacement drums that fit, 2. It's going to be damn expensive too Report
June 25, 200818 yr comment_256007 for the rear i'm using a ke55 bw68 diff, drum to drum. only the fronts are boosted. Report
June 25, 200818 yr Author comment_256039 awesome, cheers man ;) yeah not sure what I'm doing for the booster yet - will be a 13BT conversion (cause we rock in NZ and can get away with it!!) so will probably look into a booster later down the track when I get a 13B block mocked up :( Edited June 25, 200818 yr by Jarsky Report
