i've got oil on the bolts on my inlet manifold. i've no idea where it is coming from
any ideas? here is a pic.
its dry above the bolts. i've taken the bolts out and the threads are dry.
That looks like a knock sensor. What motor is it? a 4AGE. Might be worth resealing any rubber gaskets nearby with some blue goo. Looks pretty minor though.
yep, its a smallport, and that is the knock sensor. i use a haltech e6x - no knock sensor input.
so the oil is blowing up in the wind after seeping from between the block and the head?
