What was the difference in width between a TE27 and a KE20. I have bee offered a diff that i'm told is either from a TE27 or about a 74 Celica. I'm assuming from a GT. It has factory disc brakes. I'm trying to work out if it is worth putting in if I went to a 4age. I assume that if it is a TE27 one that it should bolt stright in, but a Celica one would need to be shortened (and mounts changed???)
Ian.
i doubt it's a te27 diff if it's in australia. both have 6.7" t series centers and 4x114.3 pcd. te27 suspension is different to ke25 on the front, i don't know if they run different leaves or shocks. ta22 stuff would need to be shortened, or you can run fwd offset rims on the back and it will just fit
