August 21, 200818 yr comment_269442 hey all...! i am currently putting a 5k in my ke35..but not sure if the 5k sump will fit over the 35 crossmember...will it fit? cheers Report
August 21, 200818 yr comment_269463 AFAIK it should. i pulled a 5k out of a ke35 to put into a ke20. it was a perfect fit in both. (by perfect, i mean, there was about 5mm clearance between the crank pulley and swaybar) dF Edited August 21, 200818 yr by dfunkt Report
August 21, 200818 yr comment_269465 Will fit. 5K sump is still shallow like other K motors only 7K has the wider deeper sump. Report
