How Do I Adjust My Clutch Cable
hey guys i have recently taken the gay 4 speed out of my ke38 wagon and replaced it with a 5 speed. the problem i am having is the clutch pedal lets out really high, i have had a look on the pedal and i can't seem to find an ajustment. thanks guys in advance.
there is no adjust on the pedal, just on the clutch cable itself where it goes thru the firewall. adjust the clip as taz mentioned ^^^
as they both said,
look for where the cable goes through the firewall.
should be a ridged section with an E clip against the rubber, pull the cable, remove the E clip, replace E clip in new spot and see if its better or worse.
