hi can i remove charcoal canister ,and vent my fuel tank at the back of car some how? :P
Remember its a club car not registered,don't use any of the other lines that came out of it.
Running side draft weber and battery is in the boot so its really just siting there do buggar
all,its a 55 hard top.
thanks rob
Yes you can remove it, although it would worry me having a direct fuel vent to the atmosphere, maybe work out a system that would prevent kaboom.
The ke25 only has a vent to the atmosphere from factory, they run an 8mm line all the way to the front of the vehicle, and just finish the pipe inside the chassis rail. I guess this was before charcoal canisters were invented. Maybe try that with the ke55?
