Worked 5k
hey people
i have a worked 5k whats the best sidedrafts to put?
cheers
What do you define as worked? cc's? Cam? head?
At a guess, 40mm Webers or Dellortos, 32 mm chokes, dyno time.
Expect to rebuild any second hand carbs, and don't expect to get out of it for less than $1000 if you want to do it properly.
Don't expect fuel economy.
Do expect great induction noise, torque and decent hp.
It will also depend what car they go in aswell, DCOE type carbs are a super tight fit ia a KE-1X. Even su`s with trumpets and sock are tight.
More info for everyone please
stu.
Dellortos aren't that hard to fit, mine have about 50mm clear to the strut tower. You wont be able to run long trumpets, stub stacks will be the best bet, but ramflo's or a unifilter cage will go in there.
Like mentioned, 40mm DHLAs with 28 or 32 mm chokes will do it.
