Hey, I'm wanting to do a manual conversion for my ae71..what parts am i looking at?
-t50 gearbox
-clutch master and slave cylinder and hoses
-pedal box (i can get a t18 pedal box, as far as i'm aware i just have to drill some holes in the firewall?)
do i need the manual starter motor and tailshaft aswell?
also, will i need a manual gearbox cross member? Or is the auto and manual one the same?
cheers
you will also need the clutch itself, along with pressure plate and the assoc. bearings.
i got the lot for my 4k-c from repco for around $150 bucks. std duty. heavy duty i imagine would be alot more
i can confirm on the starter. i used the same starter from my auto when doing my manual conversion
also, make sure you have the correct crossmember and tailshaft..i bought a bunch of stuff from a wrecker under instruction it was all from another ke70. turns out it was all from a ke55
oh, speedo cable will be different too (based on k series auto to k-50, dunno bout the a/t series stuff). but thats not much of an issue as you have to take out the gauge cluster to get to the pedal box bolts anyway. just gotta rip the old cable out and put the new one in
Edited by Sidewinder
