Le|Garage Posted September 13, 2008 Report Share Posted September 13, 2008 Hey, I'm wanting to do a manual conversion for my ae71..what parts am i looking at? -t50 gearbox -clutch master and slave cylinder and hoses -pedal box (i can get a t18 pedal box, as far as i'm aware i just have to drill some holes in the firewall?) do i need the manual starter motor and tailshaft aswell? also, will i need a manual gearbox cross member? Or is the auto and manual one the same? cheers Quote Link to comment Share on other sites More sharing options...
dividee Posted September 13, 2008 Report Share Posted September 13, 2008 cool I'm also interested as I'm after a manuel conversion myself Quote Link to comment Share on other sites More sharing options...
Sidewinder Posted September 14, 2008 Report Share Posted September 14, 2008 you will also need the clutch itself, along with pressure plate and the assoc. bearings. i got the lot for my 4k-c from repco for around $150 bucks. std duty. heavy duty i imagine would be alot more Quote Link to comment Share on other sites More sharing options...
Killswitch Posted September 14, 2008 Report Share Posted September 14, 2008 As far as I know you will need the crossmember and tailshaft too. Starter shouldn't matter. Quote Link to comment Share on other sites More sharing options...
Sidewinder Posted September 14, 2008 Report Share Posted September 14, 2008 (edited) i can confirm on the starter. i used the same starter from my auto when doing my manual conversion also, make sure you have the correct crossmember and tailshaft..i bought a bunch of stuff from a wrecker under instruction it was all from another ke70. turns out it was all from a ke55 oh, speedo cable will be different too (based on k series auto to k-50, dunno bout the a/t series stuff). but thats not much of an issue as you have to take out the gauge cluster to get to the pedal box bolts anyway. just gotta rip the old cable out and put the new one in Edited September 14, 2008 by Sidewinder Quote Link to comment Share on other sites More sharing options...
dividee Posted September 16, 2008 Report Share Posted September 16, 2008 so heres what i gathered: gbox clutch tailshaft T-50 x member clutch master and slave cylinder and hose pedal box have i missed anything else? Quote Link to comment Share on other sites More sharing options...
DearmanKE Posted September 19, 2008 Report Share Posted September 19, 2008 that should be it, Manual flywheel also. t18 clutch master will work, not sure about pedal box though. I have a manual ae71 gbox crossmember if someone wants to buy it Quote Link to comment Share on other sites More sharing options...
Sidewinder Posted September 19, 2008 Report Share Posted September 19, 2008 did u get pressure plate, bearings etc to go with your clutch? also make sure you check out that speedo cable too. Quote Link to comment Share on other sites More sharing options...
