neil Posted September 24, 2008 Report Posted September 24, 2008 help me out rolla club.I'm putting a 4 link in my 1j ke55 and am keen to put coilovers in the rear as the leaf mounts have to be moved anyhow. ive looked in some other threads but couldnt find any good recomendations. Quote
tas_ae71 Posted September 24, 2008 Report Posted September 24, 2008 you have a 1jz in a ke55...? :dance: anyway.. id be putting either a complete irs set-up from a s13 or similar into it. seeing as you would have to make mounts for the trailing arms to run a conventinal live axle. or alternatively you could grad yourself a tarago/hilux diff, convert to trailing arms and grab some s13 rear coilovers, (the actual coilover part would be the easiest. Quote
Redwarf Posted September 24, 2008 Report Posted September 24, 2008 Well, you're going to be fabricating like a barstard to put the 4 link in, so you may as well investigate turreting the rear like the group 4 escort. Quote
neil Posted September 24, 2008 Author Report Posted September 24, 2008 i have a sortened ford diff with skyline axles already in place. no floor as yet and mini tubs going in. i know i need to make brackets to the diff and so on but i was hoping for some second hand recomendations in the way of sizing and spring rate. this project is well underway and fabrication is not a problem. don't worry there will be pics soon. even I'm scared!! Quote
godlovesugly Posted September 25, 2008 Report Posted September 25, 2008 there was a KE20 rear-end coil over set up for sale on toymods. maybe ask that guy how he went about it Quote
gslrallysport Posted September 25, 2008 Report Posted September 25, 2008 We got a fax through from DMS (Drummond Motor Sport), who are undoubtedly the best shocks you'll buy for a street car, and if S13 does fit then there's two 50mm fully adjustable seperate bump/redbound shocks on their clearance list that are at ridiculous prices. RRP per shock is $1069 (not including springs) and they're clearing them out for $650 each, plus you'd need some 65mm race coils to match from wherever, Kings, Lovells or DMS etc. It's probably over kill, but its you've got the dollars these would be the best shocks you'll buy, and aren't just cheap blingy chinese made crap. Bit of info on the 50mm gear: http://www.dmshocks.com/shopexd.asp?id=1 If you're interested I'd have to call them and check they're still available, but at that price for what you get they're a bargain... Assuming S13 rears will work! Cheers, Greg Quote
beerhead Posted September 25, 2008 Report Posted September 25, 2008 Spot on :hmm: If you're not worried about legality then, it'll be heaps easier to mount an IRS carrier to the car than Welding the 4 link carriers on and reinforcing them. S13 sivlia will be a really close fit. If not MA61 supra or RA65 celica to keep the stud pattern right. There's a CA18DET KE30 getting around in brissy that's running the S13 gear. you have a 1jz in a ke55...? :yes: anyway.. id be putting either a complete irs set-up from a s13 or similar into it. seeing as you would have to make mounts for the trailing arms to run a conventinal live axle. or alternatively you could grad yourself a tarago/hilux diff, convert to trailing arms and grab some s13 rear coilovers, (the actual coilover part would be the easiest. Quote
DearmanKE Posted September 26, 2008 Report Posted September 26, 2008 f@$kin hell 1j in a ke55! what state u in man? Quote
