October 5, 200818 yr comment_279136 hi , am just wondering what is an easy replacement fit for a ke10 brake master cylinder. i have heard of a mazda one being a close fit. preferably want to fit a twin port master cylinder . Can anybody who has done this give me some tips. i don't want to modify the firewall too much . thanks Report
October 5, 200818 yr comment_279149 in my manual i saw that the ke10 did have a twin master cylinder factory, finding one will probably be a mission tho Report
October 6, 200818 yr comment_279577 try A.T.A.P (australian truck and auto parts) i work for a company thats does air brqake systems for trucks and we deal with these guys alot , they do alot of car brake stuff 8369-1300 , they at derrimut Edited October 6, 200818 yr by LINDSAY Report
October 6, 200818 yr comment_279592 you can just get your master cylinders honed and rekitted. i just got mine done for a ke11 and it cost me 80 bucks to get all four done and the shoes rebonded. that was the best option i could find. Report
October 6, 200818 yr comment_279593 you can just get your master cylinders honed and rekitted. i just got mine done for a ke11 and it cost me 80 bucks to get all four done and the shoes rebonded. that was the best option i could find. sorry about that just had a miss read Report
October 7, 200818 yr Author comment_279633 i actually want to know is there a replacement fit from another model or something similiar that will fit in place of the original one . has anyone used one from a mazda or nissan Report
October 7, 200818 yr comment_279635 Mazda 323 RWD, 13/16" bore, 60mm spacing for the bolt holes, although you might have to enlarge the center hole slightly (I can give you the dia. of the mazda one to compare...). Twin port, remote reservoir. As to be fitted to my 25. Report
October 7, 200818 yr Author comment_279830 thanks mate did u have to adjust the mounting bolts/stud for the 323 to fit. and was it a twin master cylinder? Report
October 18, 200818 yr comment_282324 Fitted a 11/16" twin bore early Galant M/C with KE20 proportioning valve into my KE10. Will have to enlarge the firewall hole but does the job very well. Report
October 19, 200818 yr Author comment_282729 yeah thats the one i bought the other day mate, am currently fitting it . have dsone the brass nipple and nearly finished enlarging the hole. Did u slot the holes in the master cylinder or did u adjust the mounting holes on the firewall Report
October 20, 200818 yr Author comment_283012 thanks guys all fitted up now just gotta do the brake lines . cheers for the good info Report
