Ke30 4k Fuel Pump
Hi all, I know this has probably alredy been asked, but anyone know what a good electric fuel pump for a carby 4k is and how much I would be looking at paying??
I live in NZ.
Any help would be much appreciated.
Jono.
Facet or what ever they call themselves nowdays will work a treat.
Wouldn't use a Holley unless you like sucking fuel through the hose to prime it all the time :)
Yeah mounting bracket for a holley is pretty ordinary compared to a carter, its very similar to that on your coil.
As coln72 illuded to, I personally would pick the carter as its self priming.
If you want to force induct your motor (saw sc thread) you will need to do a bit more research into what pump to use. :)
