DearmanKE Posted October 13, 2008 Report Share Posted October 13, 2008 (edited) hey guys yes i have used search so don't flame. anyway, just wondering what sorts of carby options do i have for boost on a k motor. talking to a mate said a weber would be no good as the float is brass and would just crush with boost also said that a solex might be alright anyway, discuss. -cheers Alex Edit: should probs add abit more details it will be useing an sc12 supercharger on a blow through setup, running 4-5psi boost Edited October 13, 2008 by Shizotimang Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted October 13, 2008 Report Share Posted October 13, 2008 Your mate is not fully correct. :D Yes the floats can crush......but only under very high boost pressures (like over 20 odd psi). I have personally ran over 20psi on a 32/32 weber and not even had a problem!!! Solex what? Weber is your best bet. :wink: Also worth reading this..... http://www.rollaclub.com/board/?showtopic=17418 Quote Link to comment Share on other sites More sharing options...
DearmanKE Posted October 13, 2008 Author Report Share Posted October 13, 2008 ah fair enough, with the weber i know you had a big box around the whole thing is this necassary or could i do it with just a top hat? also did u get the weber re-jetted, also whats the price for 32/32 webers, because its sounding like a good option. and yeah that fuel setup thread was real helpful. not sure what solex but apparently they have plastic float bowls that wont crush as easily. anyway, any other carbys worth considering? Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted October 14, 2008 Report Share Posted October 14, 2008 The box wasn't nessecary, it was just the easy way out. Equal pressure on both sides of the carb, so I didn't have to really worry about sealing it up well. So yes you can just use a top hat, but re-kitting the carb would be a good idea. The 32/32 DTMR-A I was using was one I stole off my brother Fiat 128 sport L, which also shares its engine with an X19 (little ferarri looking things), but I also believe these were on some Alfasuds and other euro cars of the time. Jets were re-drilled with some dyno tuning, and the neddle and seats was swapped for a much bigger falcon weber one. Thats all that was done to that carby, which FYI has twin brass floats. Quote Link to comment Share on other sites More sharing options...
DearmanKE Posted October 14, 2008 Author Report Share Posted October 14, 2008 cool cool, ive never reconned a carby before but i imagine it can't be to hard. for the amount of boost i am going to be running would it be necassary to swap the needle and seat and much work on the jets? Quote Link to comment Share on other sites More sharing options...
orangeLJ Posted October 14, 2008 Report Share Posted October 14, 2008 http://www.hangar18fabrication.com/blowthru.html give the carb thing a crack. how much do you want to spend? Any carby joint can either rebuild a carby for you to suit boost, or sell you a recoed, sealed one. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted October 14, 2008 Report Share Posted October 14, 2008 Bigger needle and seat is not nessecary, but advised. Bigger jets will drain the fuel bowls quicker, so being able to refill the bowls just as quick is a good idea. :D Main jets were soldered and re-drilled a couple of times while on the dyno, so a little bit of mucking around but well worth it. Air correction jets also needed a little bit of attention. IMHO the $260 I spent on this dyno tuning session was WELL worth it. :wink: Quote Link to comment Share on other sites More sharing options...
DearmanKE Posted October 14, 2008 Author Report Share Posted October 14, 2008 ahh fair enough don't realy have a budget, don't have the all the money at the moment id rather not put a price on it haha. but yeah each small pay i get I'm putting a descen amount towards this, Quote Link to comment Share on other sites More sharing options...
