October 14, 200818 yr comment_281529 OK, i have some new rims and the stud pattern is fine, BUT the hub center thing is bigger on the rims are bigger then what is on the car and i would need a 17mm locator to fill in the gap. What i would like to know is that: Is it alright just to let the rim sit on the studs or does it need the hub thing to rest on as well? Is it legal to do that? Would i need to get the locator machined? and where? If not, where can i find them? Over all if just letting it sit on the studs is ok and wont do it any harm is what i really want to know. Thanks. :P I'll answer any questions if i can. Edited October 14, 200818 yr by Astro Boy Report
October 14, 200818 yr Author comment_281533 Also i forgot to put in: Locator dimensions are: Outside diametre 77mm Inside diametre 60mm Sorry my mistake. and the local wheel shops we all checked only make up to 73mm on the outside so no luck so far. :P Report
October 14, 200818 yr comment_281563 Over all if just letting it sit on the studs is ok and wont do it any harm is what i really want to know. No its not ok http://planetsoarer.com/offset/studs.htm Report
October 14, 200818 yr Author comment_281565 No its not okhttp://planetsoarer.com/offset/studs.htm Thanks for that! Convinced me. :P Report
