October 17, 200818 yr comment_282178 yea, so no pod filters unless you guys no of one thats like adr approoved or something, i can make it all custom and stuff, just wanted some ideas from you guys or if anyone has done something similar, I'm going for that new engine look, nice and shiny but looks all legal. Cheers guys, hope someone can help me with this. :) Report
October 17, 200818 yr comment_282288 Speed holes son, speed holes. hha yea ay crank the drill out there u go instant cold air intake Report
October 17, 200818 yr comment_282298 Easiest way to fit a pod filter is to us a carby hat from a liteace. :) Report
October 17, 200818 yr Author comment_282307 didnt exactly want the pod filter cause most cops have a wah at them. but ill just have a pipe go down to an enclosed airbox with a dry pod filter i think. Thanks guys, and what is the liteace part? Travis Report
October 18, 200818 yr comment_282329 Just modify the stock aircleaner and run a bit of duct hose down behind the grille. Easy cold air intake! Report
October 18, 200818 yr comment_282349 Lite ace hat is no good on a nikki. If its a gemmi one it's got close to a 3" round opening on the top. I used to run a rubber joiner and PVC drain pipe right angle bend covered in black insulation tape. I just used a rubber pipe off a V6 camry after the bend with a pod on the end. Looked pretty neat and had great induction noise. Report
October 19, 200818 yr Author comment_282552 yea its a gemini one, ok souns good, when i get it ill try something similar to that, except ill just make it all out of a 3" aluminium pipe. can i use a dry pod filter or will i be defunked? Travis Report
October 22, 200817 yr comment_283556 i just stuck a little pod filter type of thing straight on top of my carb after my stock air cleaner died(engine is 3tc). i had to hack off some of the base of the filter and drill a hole in the top of the filter for the air cleaner bolt to go through and then it just all lined up perfect, i made a little gasket but i don't think it even needs the gasket, the filter was just a $20 one from repco. ill take a pic when the rain stops EDIT: car also passed rego like this no probs Edited October 22, 200817 yr by godlovesugly Report
October 22, 200817 yr comment_283561 lagality, AFAIK comes down to original fitment, if it originally had an exposed aircleaner setup, then there is nothing illegal about a POD filter. If it ran an airbox, or similar, then the pod must be enclosed. Report
October 22, 200817 yr Author comment_283649 yea, well will that be classed from the nikki carb or the 4k carb, cause I'm not sure about nikki one but 4k one was enclosed, + a different carbi = defect anyway though don't it? Travis Report
