Well, I put a timing light on it today.
My light dosent have a directional arrow for the pickup that goes on no1 lead. Tried it both ways and no difference.
Set timing to 6deg BTDC with the vacum advance un-plugged and motor at roughly 800rpm.
Then I plugged the vacum advance on and the idle turned to shit, but still reved ok.
Upon having a look with the timing light the timing went to over 20deg advanced with the vacum hose connected.
Mechanical advance works fine, car runs smooth and seems to rev nicely but I'm lost on the vac advance.
I'm unsure why it runs the way it does with the advance connected.
Thanks again guys.
Todd.
  • Replies 31
LOL this may sound dodgy but my mate rian did this the other day...
his stock 4k had a shit idle but reved ok like you said... we played around with the vacuum hoses for a while and no difference... So he pulled them all off and then reattached them randomly to each other making sure there was no vacuum leaks and no left over places to put vacuum hoses.. Ha Ha Ha the car now purs like a kitten and revs like it just rolled out of the showroom
Alittle off topic whats the screw located opposite the passenger side strut tower?
Its at the bottom of the carb (no its not idle screw)
Would i be correct to say its mixture?
KE20ROLLA: Thanks for your reply man, as i mentioned in previous post, when I hook up vacum advance it deffinatley advances. The timing mark goes over 20deg BTDC.
How would I check that the dizzy is in the right place? I assumed that it wouldnt matter as the body of the dizzy rotates 360deg.
TAZ_RXThanks also for your reply. I noticed when I set the timing right and connected the vac advance the idle turned to crap. Thought that now the timing is advanced it might need more fuel. I unscrewed the screw a few turns and noticed an improvement. Do you know how many turns out from seated the screw needs to be. I think I counted like 7 turns out from seating the screw all the way in.
Hi, does the timing go to 20 deg BTDC when idling with the vacuum connected or only when you rev it. Where abouts have you got the line going to. To check to see if the dizzy is in the right spot, take off the dizzy cap and line up the timing mark on the crankshaft pulley with TDC. The rotor should be facing either No 1 or 4 ignition lead turn the motor around until the timing mark lines up with TDC and the rotor is facing No 1 lead on the cap when the cap is installed. Remove dizzy cap and rotor and the points should be open and the rubbing block on the points should be touching the high part of the dizzy cam. :laff:
Also the vacuum advance mechanism should usually face straight front to rear in line with the engine.
If the rotor doesn't line up, then leave the timing marks lined up on TDC on No 1 and remove the dizzy and turn the rotor and place the dizzy back in until the rotor faces number 1 lead and the points are open and the rubbing block is on the high came off the lobe.
Also with the mixture, turn the screw in until it just seats and the turn it out about 2 1/2 turns. mixture is best checked when the vehicle is up to temperature. :doh:
No worries, by the sounds of it Ive got the thing running mega rich.
Vac lines are connected as per diagram that I found on this site.
Vac advance advences when on idle, its deffinatley working. I thought it may be working alittle too much. The way the mechanism is facing the vac hose goes in from the front of the car (if you know what I'm saying and Ive read what you said correctly this means its in the right spot)
I'm still unsure on the points gap no one has told me what they should be set at.
Starting to think if its not ignition it might be carby related.
Thanks again.
Quick question. Accordind to the diagram I'm sposed to have 2 things T peiced off the line to the dizzy. A VCV and a VSV.
Does any1 know what they do or if I need them.
Thanks.
Hey all,
Got all the gaps sorted. Cars runnign better.
I still am unsure about the 2 valves that are sposed to be T-peiced off the vacum line to the dizzy.
The car seems to advance the timing too far on idle, Ive set the timing almost back to 0deg.
Thanks again.
Todd.
