4k Running Troubles
hi all,
My auto 4k kE70 Is running like crap at the moment, did a service:
New dizzy cap
Rotor button
Points
Air cleaner
Put all vacum hoses back to factory (got diagram off here)
Problem now is.
runs alittle warmer (just over half way)
No midrange power.
Fuel consumption went through the roof.
I need to know the following:
1.is there a way i can test the blue temp sensitive vac valve looking thing with the hoses going to it?
2.Whats the point gap sposed to be?
3.can't run a timing light on it as the 2 marks on balancer are round 90deg away frm the indicator, car stalls when i try to move dizzy around to line one of them up.
Any feeback would be great thanks guys.
Todd.
  • Replies 31
  • Views 8.5k
Did not know there was back marks, please tell.
will check it out.
ANY Ideas on theother questions?
How do the spark plugs look? They may be fouled. Points gap, by the manual, is 0.45mm
Thanks for feedback guys.
I was under the impression that if it was too advanced it would ping?
Also brought a new set of plugs, guy told me they are resistor type cause they didnt hav normal ones in stock. Will this make a difference?
are you running the motor at 800rpm when you use the timing light?
Have you got the timing light direction going the right way, I have seen it reversed and believe me it puts you off.
What do you mean direction of timing light? I though you point and shoot?
Also, how can i check the dizzy is in the right way? Or dosent it matter?
The first thing you need to do is ignore the two marks on the front of the pulley. They are not timing marks. You are looking for a notch in the rear, top of the pulley. This is your timing mark. Put the gun on it, set your timing properly, then get back to us.
The lead that you clip onto spark plug lead #1 should have a little arrow to show the direction of spark flow. Arrow needs to point towards the spark plug, not the dizzy. :yes:
The lead that you clip onto spark plug lead #1 should have a little arrow to show the direction of spark flow. Arrow needs to point towards the spark plug, not the dizzy. :laff:
What Simon said.
No worries, Ill throw the light on it tonight and see how we go.
Changed the plugs and gapped them last night (thanks corolla nut) noticed slight improvment.
Thanks again guys.
