November 4, 200818 yr comment_287207 Hi everyone, just had my new Ae82 twin cam seca serviced and checked out by my locale mechanic and it turns out the clutch is stuffed, previous owner must have ridden the pedal alot. Also the cluthch master cylinder is leaking and needs replacing. Everything else is all good aparantly. He quoted me around 600 bucks to replace them both. does that sound about right to anyone? anyone know where to get it done cheaper or will do it for cheaper? lol cheers Report
November 4, 200818 yr comment_287218 Yep that's pretty good, anyone here who does fwd clutches regularly knows how much of a bitch they are, bit of a time consuming job. Report
November 4, 200818 yr comment_287226 Thats good when you look at labour & parts, On average you are looking at about 3-4 hours work, About 150 for a clutch kit and i think it was around 80 for the master cylinder. To do an SW20 clutch (rwd rear engine) at work the average cost is 700 bucks (prohbiding nothing else is stuffed), That includes 5 hours labour and a clutch kit aswell as machining the flywheel. Report
November 5, 200818 yr Author comment_287458 Thanks guys, thats a bit of piece of mind. I'm getting it done wednesday. thanks again Report
