November 10, 200817 yr comment_288785 ok well i have a spare gear stick and i want to turn it into a short shifter, its out of a k40, should still work in a k50 right? anyway. is it really as simple as weldind an extension on the end and turning it on a lathe so it looks the same as it did before but just longer? and then some plastic to hold it higher, however much longer you make it you stick a plate there same thickness? just make sure its straight and stuff and your set? whats a recconmended length? cheers Travis Report
November 10, 200817 yr comment_288819 Strangely enough no. The shifters are different between K40 and K50 shifters. Report
November 10, 200817 yr Author comment_288824 o really they are. damn o well. i guess ill have to pass as i don't want to hack up and risk my k50 shifter nor do i want to put in my k40 box o well cheers Report
November 10, 200817 yr comment_288830 Hi, You got the process right extend short end space it up. Now you can work it out yes. I drew it up once on paper as triangles and the big ball the stick pivits on was the fulcrum/root point the triangels were drawn from. So I workedout how far along the top one moved with your hand to how far the bottom one moved and then worked out the ratio between each one moving and presto I got kinda a ratio to use. If I find my scribble pad Ill try to scann it up for you. But about 20mm extension is about right for a K box. TRD run a 33% reduction in throw the T3 short shifter kit runs a 55% reduction. But if you make it to short and daily drive the car syncros in it might crap them self. Cheers Cameron Report
November 10, 200817 yr comment_288836 I made one for my T50, same as a KE70 K40 (maybe K50?) shifter.I used a spare shifter off a rooted 'box. I cut and extended the bottom half of the shifter rod by 10mm, and drilled/cut a 10mm spacer plate. Worked alright too, but my gears were rough enough already so i took it took it out. Edited November 10, 200817 yr by Philbo Report
November 10, 200817 yr Author comment_288841 ok cheers man thanks, scanned paper would be great ok about 20mm cheers thanks tell more about anyones experiances with them Travis Report
