November 23, 200817 yr comment_292286 I'm pretty sure i know the answer but i thought i better ask just in case. A 4k motor with a auto has the same block as a 4k manual am i right? The only diff is one has a flywheel and the other has a flex plate is that right ? Rgds Andrew Report
November 23, 200817 yr comment_292298 Yep motors are the same for each. beaten to it. :) Edited November 23, 200817 yr by Taz_Rx Report
November 23, 200817 yr comment_292345 If your converting from auto to manual, don't forget to put a spigot bearing in behind flywheel... i found mine didnt have one. and ive read auto's don't have one. Report
November 28, 200817 yr comment_293660 If your converting from auto to manual, don't forget to put a spigot bearing in behind flywheel... i found mine didnt have one. and ive read auto's don't have one. Indeed. About to attempt this conversion in a few weeks, going to pull both engines down and try and write a guide to it while I'm at it. Report
December 4, 200817 yr comment_295017 don't have a bersons in nsw Try Burson's...might have better luck there... Report
December 4, 200817 yr comment_295161 Try Burson's...might have better luck there... :yes: should have known Report
