67Rolla-Ken Posted December 6, 2008 Author Report Share Posted December 6, 2008 Yeh had noticed the damaged screw. not worried because these come in the kit. Will definately be cleaning thoroughly. Quote Link to comment Share on other sites More sharing options...
KE30_KE35_KE55 Posted December 6, 2008 Report Share Posted December 6, 2008 (edited) Yeh had noticed the damaged screw. not worried because these come in the kit. Will definately be cleaning thoroughly. Make sure both venturi,s are the same size, also be carefull not to swap venturi tubes with a standard carby as singles will be slightly larger and you will develop a flat spot. Edited December 6, 2008 by KE30_KE35_KE55 Quote Link to comment Share on other sites More sharing options...
coln72 Posted December 6, 2008 Report Share Posted December 6, 2008 Never had an issue running two "single" carbies instead of the proper 3KB ones, if that makes sense. Quote Link to comment Share on other sites More sharing options...
KE30_KE35_KE55 Posted December 6, 2008 Report Share Posted December 6, 2008 (edited) Never had an issue running two "single" carbies instead of the proper 3KB ones, if that makes sense. The main thing is that they are the same so its balanced for tuning, the larger venturi could cause a flat spot depends how you drive it too. Edited December 6, 2008 by KE30_KE35_KE55 Quote Link to comment Share on other sites More sharing options...
Browland Posted December 7, 2008 Report Share Posted December 7, 2008 Sounds like I owe you a prize... my gratitude good enough for you? :'( Yep thats fine. Just the satisfaction of someone using these for "originality" is good enough for me. There not a high performance carburettor but factory go-fast parts look cool. Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted December 7, 2008 Author Report Share Posted December 7, 2008 THat's exactly the plan, show'n'shine & a little bit of fun... Quote Link to comment Share on other sites More sharing options...
