December 11, 200817 yr comment_297017 i hav no power from my coil to the dizzy on a stock 4ac in a ae71 :D any help would be much appreciated :P Report
December 11, 200817 yr Author comment_297025 high tension or low tension lead? i dunno man it just has power at the wire on the solanoid or whatever it is on the side of the coil but not at the top of the coil if you understand what i'm saying Report
December 11, 200817 yr comment_297038 By the sound of it you mean the ballast resistor? If it is open circuit replace it.. coil should still get 12v on crank though.. Report
December 11, 200817 yr Author comment_297064 By the sound of it you mean the ballast resistor? If it is open circuit replace it.. coil should still get 12v on crank though.. tha coil is gettin power to the resistor but not to the coil can i jus pull the resistor off and put a betta coil on it?? Report
December 11, 200817 yr comment_297073 What you are saying makes no sense, The coil gets power via the ballast resistor (Drops the voltage to around 6V). Where abouts in Brisbane are you from? Report
December 11, 200817 yr Author comment_297087 What you are saying makes no sense, The coil gets power via the ballast resistor (Drops the voltage to around 6V). Where abouts in Brisbane are you from? hillcrest, i don't undastand electrics man i can just about do anythin mechanical but throw electrics at me an i hav nearly no idea aye so even if i put a better coil pack on it i will hav 2 keep the ballast resistor right??? i'm only askin coz i don't know!!! Report
December 11, 200817 yr comment_297088 The coil could be fine, It may just be it is not wired right. Then of course the ballast resistors do let go and they don't keep power to the coil after crank.. If you need a hand let me know, I work over that side of town and can come have a look after work tomorrow.. Report
December 11, 200817 yr Author comment_297092 The coil could be fine, It may just be it is not wired right. Then of course the ballast resistors do let go and they don't keep power to the coil after crank.. If you need a hand let me know, I work over that side of town and can come have a look after work tomorrow.. yeah cheers bud would b much appreciated, i checked all tha wiring it was running fine las nit tha car is unreg'd but it's jus annoyin not havin it running till i find a 4agze to put in it Report
December 30, 200817 yr comment_302645 Mine is doing the same, have cheaked the power to the coil, there is power but not 12v, just don't give spark to distributor??? Report
December 30, 200817 yr comment_302752 its wired wrong.. Had same prob, had all the wires back to front. forgot how i fixed it though, think i had wire from dizzy to coil on the negative side instead of positive.. or other way around? :) Report
December 30, 200817 yr comment_302832 Mine is doing the same, have cheaked the power to the coil, there is power but not 12v, just don't give spark to distributor??? have you tried cleaning the contact points inside the distributer yet? Report
