December 17, 200817 yr comment_298993 Still looking at power upgrades for the 4AFE-- this is becasue of the 4WD gearbox cut out in the block issue with the AE95R- my car I have been trying to find pictures of the 4AGZE block to see if it has the cut out in it-- no joy as yet the wreckers I went to today didn't have a ZE engine there for me to compare. If a 4AGZE has the cut out it might just be easier to get a front cut and do the whole changeover thing, ECU, etc-- any help on the ZE block having the cut out would be nice failing that I was thinking how hard would it be to graft a ZE topend to my 4AFE so in reading up here there seems to be 2 types of ZE- TPS and MAP which type is more simple - the grunt will be great from either type compared to normal 4AFE performance so I'm looking for the simplest to fit I have a series 1 4AFE from a 1988 AE95R The increase in torque will be most helpfull in getting the 4wd to move better so any help will be great -- or would a 7AFE conversion be easier? thanks heaps in advance P Report
December 17, 200817 yr comment_299015 4AGZE has been done before with block mods, needs a few mm shaved off here and there. Rumour is the 20V block has the notch you're speaking of. A GZE head and factory manifolds / charger should work ok, pretty low compression though. Report
December 19, 200817 yr comment_299422 4wd 4agze has definatly been done. have a look at the 4wd corolla wagon on toymods( i think? mighta been ae86dc ) on airbags, 4agze and respray! Report
December 19, 200817 yr comment_299463 Speak to Kebin (his name is Kevin) on this site. He has a 4agze in an AE95 Beautiful car too and i beleive he did most of the work himself Report
December 19, 200817 yr comment_299564 4AFZE - the bottom end may not last too long on boost, its not desgned for it. It's a bit $$$ to do properly, but have you considered a 7AGE? They are torquier (is that a word?) than a 4AGE and use a 7AFE block, so might bolt up to the AE95 gearbox without mods. Edited December 19, 200817 yr by machg Report
