Cams For A 4age
does anyone know were i can get better cams for a 4age in qld :y:
i am aiming to make mine rev to about 9 and a half :)
Tighe Cams.
Personally I wouldn't build another engine to rev that high. They're a bit pointless. I know the 4AG will do it, but you really sacrifice anything down low, which makes it hard to drive on the road, and believe it or not, on the track, unless you're a serious peddler with clairvoyant gear selection.
i am hopin to get it out that far but with a turbo hopin keyword
what even without a turbo but high comp pistons and a ported an polished head???
I laughed so hard when a mate of mine told me he was building a 4AGE that will redline at 11500rpm. Even if the oil pump somehow didn't blow itself to pieces (not to mention the rest of the engine), it's either going to have stopped making power at 6k or will have absolutely zero torque.
i don't understand, revving to 11000rpm works in the cartoons, why not in real life?
:lmao:
it does work, check out 6boost's 1g.
but thats purpose built drag.
doesnt make any power til 5500.
and if it were me, id be buying something like HKS or whoever else cams for these motors, all the regrind places, i wouldnt trust them to have done their research...
cheers, andrew
:bash:
haha only happens if you park your panda ae86 outside a real tofu shop :y:
on the subject of camshafts and turbos...
bigger camshafts and high static compression ratio are a typical NA build not turbo,
recently higher compression turbo builds have been made but its not really
that common yet except for low boost oem or unstreetable big power builds.
i would imagine the bigger the cams and bigger the turbo you go would make it
very unstreetable with turbo lag combined with the camshaft power band moving
way up in the rev range and the idle being turned far up.
bigger camshafts have a longer duration - they open earlier and close later, so you
need a high static compression ratio because the bigger cams lose more of the
compression and you need the dynamic compression ratio to end up somewhere usable.
thats why the bigger the cam the higher the static compression ratio, so the dynamic ratio
ends up about the same generally.
static compression is engine volume with piston at bottom / piston at top ( / = divide)
dynamic compression ratio is the same but now with the camshaft opening and closing
and letting the fuel mixture enter and escape as the piston moves up and down affecting the
volumes measured.
Edited by styler
