johnny t Posted March 1, 2009 Report Posted March 1, 2009 hey guys just wondering what ke30/ round headlight grill has the most room behind it? because i had to cut my intercooler in to this one in the pic and i don't like it. and i want to try eliminate re mounting my intercooler! cause of my stainless pipes and everything has already been made.. or a way to mount the ke55 headlights into it so i can use the honeycombe grill in it like i did in my ke55 or any other suggestions to solve my problem. any opinion would be helpful! johnnyt Quote
RedKE30 Posted March 1, 2009 Report Posted March 1, 2009 (edited) or a way to mount the ke55 headlights into it so i can use the honeycombe grill in it like i did in my ke55 My KE30 has the square headlights with the honeycombe grill. I didn't fit them, but looks as though the headlights were just lined up then had holes drilled into the radiator support panel and mounted with the square headlight brackets. Be careful if you do this though because my grill doesn't fit right now. Edited March 1, 2009 by RedKE30 Quote
JiP Posted March 1, 2009 Report Posted March 1, 2009 I would believe that the late KE30 grill (pictured) would be the only one with space. If you would go KE55, then it would be the square headlight one. Tho now that i think about it any 55 grille may do. Quote
johnny t Posted March 2, 2009 Author Report Posted March 2, 2009 yeah my 55 had the brackets for the head lights but my 30 doesnt i guess I'm just gonna have to look around for the right grill if i can't find it ill just leave it.. thanks guys Quote
JiP Posted March 2, 2009 Report Posted March 2, 2009 Brackets for the head lights?? As far as I know the KE30's had a bracket just the same as the KE55's did. The only difference is that the bracket on the KE55 is bigger. Quote
