March 8, 200917 yr comment_325582 hey all. yesteray my engine fell over in my bay....... :locked: :yes: wasn't secured real well and on one of my plastic covers a bolt hole lug has snapped off. these cover are pretty hard to find so i need to have this one fixed. there is plenty of meat in the plastic. so does anyone have a number for a place that'll do polywelding? or anyone have a welder and is good at it? cheers, Luc Report
March 8, 200917 yr comment_325615 what cover is it? Put a pic up, poly welders are typically polyethylene and I doubt there's many polyethylene covers on your engine. You'll need to work out what plastic it is first. Report
March 8, 200917 yr comment_325636 If only you were in melb. I have a mate thats good at plastic welding. I snapped my fan shroud clean in half and he welded and finished it perfectly! Ale Report
March 8, 200917 yr Author comment_325650 well I'm'm gonna ring toyota on tuesday and see if i can get one new. if not then i'll probs send it to you maybe? Report
March 8, 200917 yr comment_325695 cheaply you can pick one of this in your local wrecking yard??if not soldering iron,melt the broken sides a bit to make it soft and put pressure and VIOLA!!your done.hope it helps as i do it this way its easily and a cheap way! Edited March 8, 200917 yr by drc_ke20 Report
March 8, 200917 yr Author comment_325730 ahk thats a good idea. mix that process with some hot glue? but no way would i find this at a wrecking yard! its from a 4age 20v. Report
March 8, 200917 yr comment_325752 I'm sure its the same as the 4age front timing cover so you can use any other,i will check mine in the morning and compare it with your one???i will let you know. Report
March 8, 200917 yr comment_325824 I don't like your chances man - I reckon that might be a Thermoset type of plastic (as opposed to a Thermoplastic), most engine parts usually are. Thermosets usually handle higher heat than Thermoplastic, and they generally just char/burn under heat. You won't be able to melt it, you're best bet would be gluing. Thermoplastics do melt though, you could try the soldering iron and you'll soon work out what you have. On the inside of the part should be a bunch of date-dials and an abbreviation like PE/PP/PUR or similar. Let me know what it is. Report
March 8, 200917 yr comment_325838 I'm sure its the same as the 4age front timing cover so you can use any other,i will check mine in the morning and compare it with your one???i will let you know. they are different between the 20v and 16v Report
March 9, 200917 yr Author comment_325937 ok it has TBC NO.2 then toyota part number. then it has P.PT Report
March 10, 200917 yr comment_326527 okit has TBC NO.2 then toyota part number. then it has P.PT If all else fails there was a 20 valve motor in the trading post in SA last week that required rebuild for $450. Rebuild was due to being smoky apparently. Purchase and sell off all the good bits and keep the plastic cover = win. The quad throttles alone would be worth $200. And the head would be good for someone for another $150 or so. The guy selling was a bit of an enchilada though but he might be getting desperate by now as it's been for sale for over a week. :D Report
March 11, 200917 yr Author comment_326650 ahk well nah i don have those sorta funds. so yeah. i rang toyota and they are 86.70 but they need to order thru japan so shipping is about $40 and there will be a three month wait. not bad really for a brand new one. Report
March 11, 200917 yr comment_326652 ahk well nah i don have those sorta funds. so yeah.i rang toyota and they are 86.70 but they need to order thru japan so shipping is about $40 and there will be a three month wait. not bad really for a brand new one. Have you thought about trying Castle Hill Toyota? They specialise in import parts and promise to have stuff in within 10 business days from Japan. I bought some things from them for my JZA80 and they were awesome to deal with. www.chtoyota.com or something similar just google it. Report
March 11, 200917 yr Author comment_326654 hmmm well i rang christies beach toyota and they ckecked aus for any and said none. also current orders and nil. he reckons most likely japan wont have any either and they'll probably have to make it. Report
