Leaking Boot
Hey, I've got a really bad leak in the boot of my seca witch fills up the wheel well with water wen it rains.
I've checked the the seals around the door and also around the tail lights but had no luck.
Any suggestions were its coming from?
the sky? just weld the boot shut might help
maybe the glass rubber? run a hose around all the seals and the window rubber and see wheres its coming from then seal it
or you could put a hole in the wheel well and let it drain. noone will ever know
Edited by TC16
get a mate and have a hose running water onto it while someone is inside..
Yeah I've taken the rubber bung outta the wheel well for it to drain but the carpet in the back still gets wet and my speaker box soaks up the water as well.
Ill try the hose on the seals anyway, cheers
try checking it at night with a light around the rubber seals? the boot in my ke30 was leaking too and i couldn't find it so i ran water near the seals and along the sides but in the end a torch is what did the trick for me.
good luck
don't use silicone to seal it, its useless and causes rust. Use mastik sealer
Found the leak, bloddy rust all the way along the bottom edge of the glass.
Might see how much it is to fix it but might just buy a whole new back door.
Anyone got a decent boot door?:y:
